DAX 2012 - AIF error
I tried to create a vendor using AIF framework in DAX 2012 and I received following error -
VendTable.createList\Line=1, Pos=386, Xpath=/VendTable/VendTable[1]/DirPartyTable[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=646, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/OrganizationName[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=705, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/OrganizationName[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=723, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyPostalAddressView[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=723, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyPostalAddressView[1] Field ‘Name’ must be filled in.
VendTable.createList\Line=1, Pos=1066, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyPostalAddressView[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=1093, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyContactInfoView[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList\Line=1, Pos=1093, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyContactInfoView[1] Field ‘Name’ must be filled in.
VendTable.createList\Line=1, Pos=1338, Xpath=/VendTable/VendTable[1]/DirPartyTable[1]/DirPartyContactInfoView[1] This document does not support the AxDirOrganizationBase class.
VendTable.createList This document does not support the AxDirOrganizationBase class.
VendTable.createList Creation has been cancelled.
I modelled this code based on DAX 2012 import utility. Version of AX - 6.0.947.61
How can I fix this error? Any help would be greatly appreciated.
Best wishes,
Harish
Hi, Could you please post your C# code. looks like you are missing to expose/register few web services in to C# solution.
Let me re execute your code in my window.
Udhay
I am not using C#. I read data from CSV file with in X++ and then call the vendor document service.
Also the bizarre thing is - the same way, I am able to create customers successfully. I am getting the above error only while trying to create vendor.
A quick update -
I solved this issue by changing the data object class from VendVendTable_DirPartyTable_DirOrganizat to VendVendTable_DirPartyTable_DirOrganiza1.
I hope the above info is useful for someone some day.
Hi Harish,
I am getting the same error. I am using AX 2012 R2 (Build 6.2.158.0).
Both the classes ‘VendVendTable_DirPartyTable_DirOrganiza1’ and ‘VendVendTable_DirPartyTable_DirOrganizat’ are present in sys layer foundation model.
Any idea what was the real problem in your case? May be it will help solve problem in R2 as well?
Deepak
