Datewise Item Details in Matrix Format.
Dear frnds,
Can anyone give some idea about that " How i can make a form in Matrix Format " where the result should be display the item inventory as per date wise. [:D][H][}]
You have not mention the version which you are using
Look at the following Link
http://www.mibuso.com/howtoinfo.asp?FileID=13
As well as Look at the standard Matrix form also.
I am using Navision 2009R2 version.
And thank you for that Solution. [:D][:)]
