Help please, what am I missing?.
I am trying to get an end date but it is not correct due I suspect to the different number of days from June to March as per the example below:
“End Date” = 30/06/13
“S.Term” = 3M
StartDate should be 01/04/13 but is calculated as 31/03/13
Code: Navision 3.7
( “S.Term” = DateFormula)
TermText := FORMAT(“S.Term”);
IF TermText <> ‘’ THEN BEGIN
IF “End Date” <> 0D THEN BEGIN
TermText := ‘-’ + TermText;
StartDate := CALCDATE(TermText,“End Date”);
StartDate := CALCDATE(’+1D’ , StartDate);
END;
DRB
June 25, 2013, 7:11pm
2
I think
is not required.
You are calculating date 3 months before, which will be 30/03/2013 in your example case, if you want to know a day 90 days before then instead of ‘-3M’ use, ‘-90D’.
If you want the last day of the month as the end date, use CM
StartDate:= Calcdate(‘CM’, StartDate);
If you want the first day of the month, then just find the last day using CM and add a day.
The code may not be as graceful as I could do if I put time into it but the basic idea is there.
