Hi
When I try to create a new employee the following error shows up
May I know the issue?
Hello,
Its stating that there is an error in the method setParamaeters of class DateEffectivenessCheck. I suggest you to check what customization is done in that method.
Compile the code. Either there is a compilation error (which you’ll have to fix) or the code hasn’t been compiled correctly and the compilation will fix the problem.
If it’s not a development environment, you have a bug in your deployment process.
I cleared it, Thanks Wekey.
Please tell us what was wrong, it may help others with similar problems.
Thanks, Martin.
In setparameter method
COmpiled the code and now I can create a new employee.
Also there is an error showed up like there is more incomplete start and end time
Initially I didn’t filled this tab, I think that error is from this field.
May I know why this fields are important?
