I was uploading some data into NAV in the web client which is working fine but I have challenged when uploading into windows client, error message: “The value “06/29/2012” can’t be evaluated into type Date”. And the date format is mm/dd/yyy while the system is seeing the date format as dd/mm/yyy. I need your assistance in date format of the system. Thanks.
yes you can correct the changes in the system obviously. what i wanted to understand is why there is difference in web client and windows client date formats, date formats should be same if you have them on same system - i might not have understood the issue
Remember, web client is using Server date format. While prepare a report and I selected a date which it pick the date format of the windows client dd/mm/yyy. Thanks.
I have solved it by clicking Notification - Setting - Time & Language - Change date and time format - Short Date (I added the date format here MM/dd/yyyy) – Windows 10 desktop.
