Dataport Validation
I have created before several “journal import dataports” that is not validating the fields that are imported. I have set the property of every dataport field to validate the data before import, but not all the fields in the dataport is validated.
I assume that this problem is due to the order of how data is imported. Therefore, I have modified the field import sequence as per the field sequence in the journal. And again, it is not validated. At the end, I have to write coding to manually validate each and every field.
Any ideas what could have caused this?
Check this http://dynamicsuser.net/forums/p/12120/59056.aspx
