Dataport using AutoReplace
The online help on the field “AutoReplace” of the properties of a DataItem states "When AutoUpdate is Yes, an imported record that has the same primary key as an existing record will be updated with values from the record already in the database for those fields that do not contain values." When I leave all the other setting to default, an import overrides all fields that were filled in the database but not sepecified in the txt File. [?][?]
You probably ran the dataport during the wrong phase of the moon. [}:)] Unfortunately, the AutoReplace/Update/Insert never seem to do exactly what you expect. Safest bet is t owrite the code manually.[V]
Thanks David. At least dealing with Navision doesn’t get boring [8D]
