I created a dataport to import data frm a CSV file. The dataitem table is members and the key is Entry No. which is an integer.
My CSV file lacks the entry no. collumn which should increment by one every time a new records is imported.
Imagine the import is said to be successful but only imports one record out of the many available(The last one in the CSV file). What could be the reason to this.
NB The import process is not gererating any error but only imports the last record of the file.
Another suggestion is to reset the Entry No to zero (assuming an Autoincrement) after each record otherwise the dataport overwrites each time leaving you with the last record.
Am not sure if i got what u guys are suggesting. Could u plz be quite detailed. Do i need to write some code on before import record to determine the entry no or do i include the entry No collumn on my file.
