I have an issue with dataports. I am using Navision 3.60, with Win 2000 operating system and SQL 2K. I need to import sales orders with German characters. The problem is that when I import it, the data becomes junk. Now i remeber this has something to do with the fact that Navison uses Ascii and Microsoft Unicode. Somebody knows about this problem or any partial o final solution. Help would be appreciated. Thanks and Regards, Omair
Michael Buecher had the same issue on the German forum (if you can read it): http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=9675 Download and use this codeunit, it should work for you too: http://www.mibuso.com/dlinfo.asp?FileID=287
Hello, Navision was not the right way to solve this issue. I could solve this issue, I added to my C++ application a file’s converter betwen ANSI and ASCII Files and when I have my file in ASCII code then I can import this data to my SQL Server and I can read the correct information using Navision. I found an usefull code in http://www.programmersheaven.com/search/download.asp?fileid=19874 If anybody need to convert characters between different languages, I think is possible to solve it converting to ASCII independently to Navision and SQL Sever.
