Hi everybody,
I have prepared a dataport to introduce many information to the table Contact Profile Answer (5089) on the Navision 2009 SP1, the dataport includes the following fields:
“Contact No.” - “Profile Questionnaire Code” - “Line No.” - “Contact Company No.” - “Last Date Updated”
The problem is that when I run the dataport, i runs correctly, but when I go to the table no data is inserted… I have changed the 3 properties AutoSave, AutoUpdate and AutoReplace to different values, and nothing happens. Also I have tried to put more fields in the dataport (like the value, the company and contact names, the answer)…but I obtain the same results.
Can anybody help me in how to make this?
The format of the text file to import, is correct, because I have made many other dataports, and never I have had this issue.
thank you in advance!!!
