dataitem
hi
please give me the clarity description regarding data item in report object…
can we compare this data item as data set which is .net…
yes a bit, its self executing dataset, where you can procsses output field values and display on section.
thanq anil
I remember in Dataset you can have zero or more table(s), however NAV data Item is refering to one Table only which is the one it is defined for.
