hi folks
how to check the version of the database
how to find the database is realated to global or localized?
thanks & regards
hi folks
thanks & regards
You can see version on About screen. On top menu select Help → About Microsoft Business Solutions - Navision.
W1 means that it is worldwide. Between brackets you can see version of executables.
Much more database affairs info can be checked on File → Database → Info:
I need a [C] !!
The help-screen might state something like "Version DK 4.00 SP1 (4.0 SP3) " which means:
So - you cannot not quite rely on the applicationversion
Btw - if you double-click on the version-info in the help-screen you get FIN.EXE-file’s build-no.
And - by reading the database.fdb-file itself in binary mode it is possible by the 5th byte to see which exe-version it belongs to. But that is another story.
