Database Wizard
Hello, Periodically (every 2 months I believe), Axapta requires to optimize its database. A wizard is launched at the starting of Axapta. Can we disable this function in the software, because it is very annoying when the first station which boot in the morning is an “automatic” station for batchs processing. This “batch” station remains blocked until somebody comes to click on “Cancel”. Thank you for your assistance, Eric
Go to the Menus Tools\Option and then select Sql tab. Here u can set ur database setting what’s u need.
If u run the batch processing once, then this wizard never comes, untill any changes in that selected database setting.
