I am working in Navision 5.0 and we are looking in for a database migration from NAV to the SQL server . Can you let me know the procedure and method involved in it.
As such i know how to restore database in SQL front and start working with a fresh database , but i have no idea on the migration part. It would be great if you can share you experience and also tell me what are necessary requirement to proceed on this.
I tried searching it from patnersource and found the SQL server technical kit. Then i thought if i put it in forum i can get a better and experience reply from you pepole who have done it or tried it.
Can you tell me the steps involved in doing this. I mean you might have a procedure created on the same and all the softwares that are supposed to be used for this.
The process is good and simple but I can not repeat everything that is in the Microsoft documentation so please read the w1w1upgr.pdf .
Work throught the process step by step in your QA or Test environment. If you don’t have a test environment then make one now. It does not need to be a big database. You could use the Demo database…
Remember that the best way to learn how to do something is to do it.
When you have some specific questions I am sure that we will be able to help.
