Hi All
Data Upgrading from NAV 2013 to NAV 2013 R2.
Followed steps below :-
Done object migration from 2013 to 2013 R2
Open 2013 DB in 2013 R2 development environment, uploaded 2013 R2 developer license.
Created NAV service instance and opened DB in 2013 R2
Imported Upgrade700701.1 objects in 2013R2 DB and Transfer Old data process
Delete Objects except table from tool
Imported merged objects in 2013 R2 DB and compiled
Done Build Server Application objects
Restarted NAV Service instance (given all permission to the network service and administrator)
9 ) Trying to open DB but getting below Error’s
i) 1st time error –“a connection to the server has been established. preparing your workspace”
Given cancel and tried
ii) 2nd Error
Microsoft Dynamics NAV
The operation could not complete because a record in the General Ledger Setup table was locked by another user. Please retry the activity.
OK
iii) went to event viewer following error showing…
Type: Microsoft.Dynamics.Nav.Client.NavClientClosingException
Fatal: False
ShowError: True
Message: The server “Shravan2013R2March” was unable to process the request. The application will close.
StackTrace:
at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoExecute(Func`1 execute)
at Microsoft.Dynamics.Nav.Client.WinClient.StartWinFormsClient.RunCore()
Source: Microsoft.Dynamics.Nav.Client.WinClient
HResult: -2146233088
Type: Microsoft.Dynamics.Nav.Types.Exceptions.NavServerSessionException
StackTrace:
at Microsoft.Dynamics.Nav.Client.ConnectionEstablisher.OpenConnection(ConnectFailedEventArgs connectFailedArgs, ConnectionRequest connectionRequest, SpnSetting spnSettingToTry, Boolean allowSpnSettingsSwap, UserSettings& userSettings)
at Microsoft.Dynamics.Nav.Client.ConnectionEstablisher.OpenConnection(ConnectionRequest connectionRequest, UserSettings& userSettings)
at Microsoft.Dynamics.Nav.Client.ServiceConnection.OpenConnection()
at Microsoft.Dynamics.Nav.Client.ServiceConnection.Initialize()
at Microsoft.Dynamics.Nav.Client.FormBuilder.BuilderSessionInitializer.InitializeService(IService service)
at Microsoft.Dynamics.Nav.Client.FormBuilder.BuilderSessionInitializer.OpenConnectionToServer()
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.OpenServerConnectionCore()
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.OpenServerConnectionWithMultipleLoginAttempts()
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.InitializeUISession()
at Microsoft.Dynamics.Framework.UI.Windows.ClientSessionBase.SetupSessions()
at Microsoft.Dynamics.Framework.UI.Windows.ClientSessionBase.InitCore()
at Microsoft.Dynamics.Nav.Client.WinClient.NavWinFormsClientSession.InitCore()
at Microsoft.Dynamics.Framework.UI.ClientSessionCore.Init()
at Microsoft.Dynamics.Framework.UI.Windows.ClientSessionBase.Run()
at Microsoft.Dynamics.Nav.Client.WinClient.NavClientErrorHandler.ExecuteAndCatchExceptions(Func`1 execute)
Source: Microsoft.Dynamics.Nav.Client.ServiceConnection
Type: System.NullReferenceException
Message: Object reference not set to an instance of an object.
StackTrace:
at Microsoft.Dynamics.Nav.Runtime.NCLCaptionStrings.GetValueOrDefault()
at Microsoft.Dynamics.Nav.Runtime.NavSqlDatabaseSync.SynchronizeTableChanges(NavDatabase tenantDatabase, Boolean changedSortingProperties, IEnumerable`1 tableChanges, Int32[] companyTokens, SyncMode syncMode, Boolean databaseConvertedFromNav2013)
at Microsoft.Dynamics.Nav.Runtime.NavSqlDatabaseSync.SynchronizeTenantDatabase(NavDatabase tenantDatabase)
at Microsoft.Dynamics.Nav.Runtime.NavDatabase.EnsureDatabaseInSync()
at Microsoft.Dynamics.Nav.Runtime.NavUser.GetAllUsers(NavDatabase database)
at Microsoft.Dynamics.Nav.Runtime.NavUserCache.RefreshList()
at Microsoft.Dynamics.Nav.Runtime.NavUserCache.TryGetNavUser(Func`2 match, NavUser& user)
at Microsoft.Dynamics.Nav.Runtime.NavUserAuthentication.InternalAuthenticate()
at Microsoft.Dynamics.Nav.Runtime.NavUserAuthentication…ctor(NavTenant tenant, NavClientCredentialType credentialType, Object token)
at Microsoft.Dynamics.Nav.Service.NSServiceBase.ValidateAndCreateSession(ConnectionRequest connectionRequest, Boolean requireNavUser)
at Microsoft.Dynamics.Nav.Service.ServiceOperationInvoker.CreateNewSessionCombinator(ServiceOperation innerOperation, NSServiceBase serviceInstance, Boolean requireNavUser, Object[] inputs, Object[]& outputs)
Source: Microsoft.Dynamics.Nav.Ncl
HResult: -2147467261
- yet to import Upgrade700701.2 objects in 2013 R2 DB and transfer new data process– pending
Someone please help me on this issue.
Muthu
