DATA upgrade
I am doing data conversion NAV R2 to NAV 2013 when import all object Old version open NAV 13(after compare and merge) then I am facing the error in Transfer Line table.
You cannot delete or change the type of the Unit Cost field (in the Transfer Line table) before the value in the field is reduced to 0 (zero) or ‘’ (blank) in all records. This message occurred because a nonzero value was found for the record Document No.=‘MR/1112/0002’,Line No.=‘10000’ in company AVI - 01042011.
http://dynamicsuser.net/members/smishra/files/DOC.png.aspx
Please check the field before you do teh data conversion… looks like the merge has not taken care of this field… need to find if unit cost has been taken care in nav 2013 or the field is deleted.?
