I have a question about data transfer from an external MS ACCESS2 into a Navision file. In the ACCESS2 file is a field with the data type MEMO. The length of this field can be 64000 characters. The content of this field are text data’s whit different length’s. How can I implement this field into a file which include text fields with a fix field length ? Best regards Edwin
Hello Edwin, I did this a couple of times. As I like programming in Delphi, I did this by 1) Looping through the access table 2) reading the memo field into a memo component 3) looping through the memo component lines and 4) writing the lines into a new text lines table. Would you like some help? Pelle
quote:
Originally posted by pelle: Hello Edwin, I did this a couple of times. As I like programming in Delphi, I did this by 1) Looping through the access table 2) reading the memo field into a memo component 3) looping through the memo component lines and 4) writing the lines into a new text lines table. Would you like some help? Pelle
Hi Pelle, if you can help me this will be very good. My problem is, we don’t have Delphi on our System. Edwin
Edwin, email me the zipped access table if it isn’t too confidential. pl@seldenmast.se Pelle
Edwin, You can implement it without any programming in two following steps: 1. Export the memo field of your MS Access table into a text file. If you do not want to make an export procedure, just copy this field and paste into notepad. 2. Import existing text file into Navision table via dataport. Good luck. Regards, Yuri Pokusaev IBS, Senior Consultant NCPS, NCSD ypokusaev@yahoo.com +7(095)967-8080
Yuri, this sounds simple enough, but the text file created from the memo field needs some more information to handle the referential integrety: References to the “parent” table + line no (i.e. “Item No.”, “Line No.”.) Where do you get that info from? Pelle
Dear Pelle, My previous design was a rather simple. I absolutely agree with your requirements above. Therefore I would like to offer another decision. I believe, it will be useful for a person not familiar with Delphi.
**Prerequisites:**
1. MS Access (VBA)
2. Dataport object of Navision Attain
**Example:**
**(1) Table Structure**
MemoTable
Index LongInt
mem Memo
**(2) VBA Code**
Public Function WriteNAImportFile()
Dim mytable As Recordset
Dim ifile As Integer
Dim iStrPos As Integer
Dim iStrLen As Integer
Dim iCounter As Integer
ifile = FreeFile()
Open "D:\import.txt" For Output As #ifile
Set mytable = DBEngine(0).Databases(0).OpenRecordset("MemoTable")
mytable.MoveFirst
While Not mytable.EOF
If IsEmpty(mytable!mem) Or IsNull(mytable!mem) Then
Write #ifile, mytable!Index & "", "0", ""
Else
iStrPos = 0
iCounter = 0
iStrLen = InStr(iStrPos + 1, mytable!mem, Chr(10)) - iStrPos - 1
While iStrLen > 0
Write #ifile, mytable!Index & "", iCounter & "", Mid$(mytable!mem, iStrPos + 1, iStrLen - 1)
iCounter = iCounter + 1
iStrPos = iStrPos + iStrLen + 1
Wend
End If
mytable.MoveNext
Wend
Close #ifile
End Function
**(3) Output Access-to-NA import-file Structure:**
Comma-Separated
Field Delimited is [ “ ]
Fields: “< Key Field Value >”,”< Line No. >”,”< Memo Line (< Line No. >) >”
Example:
"1","0","string 1"
"1","1","string 2"
