newnw
November 16, 2009, 12:28am
1
when we importing data to NAV, do we have to have the same data fileld sequens in the NAV table as it is in the txt file.
eg- txt - name,add,tel,dob but my NAV table have those fileds in thisway- name,dob ,add,tel
if both file have the same sequence then there is no problem, but when field sequence is different I’m unable to import data.
DenSter
November 16, 2009, 2:39am
2
The fields in your dataport must have the same order as the fields in your text file. That is not necessarily the same order of those fields in the table design though.
newnw
November 16, 2009, 11:27am
3
Thank youvery muchfor your help, every day i’m learning new things. onceagain thank you for your support.
DenSter
November 16, 2009, 1:29pm
4
No problem, glad you were able to make that work [Y]
