Data or calculated fields with type 'Void' are not supported.
I am getting the below error while runing the report, in ax 2012 r3
Data or calculated fields with type ‘Void’ are not supported.
any suggestions please.
Just change the temp table to regular table and change the property of created transaction id to yes.
Note the change.If problem persist then Make sure you select all the fields from temp table rather than certain fields.
Check this one…
https://community.dynamics.com/ax/f/33/t/174888
select all fields from temp table?
Do you mean in Datasets , must select all the fields in Visual studio
yeah of course , try to select all fields from temp table ,don’t select certain fields alone.
In my case , all fields are selected
still getting same error.
when printing original preview of sales invoice journals
Have you added any fields after deploying it from VS?
see just delete the entire fields from temp table and rebuild everything with the same fields and refresh the dataset in VS.
