Hi Forum, we have installed a US version of Nav 2013 and I am in the process of testing but have come across some strange behaviour. When I create a Sales Order, non of the data is visible unless you click in the field and then it shows.For example, if I click in the Sell to Customer name I can see the data but otherwise it is invisible. Has anyone come across this before and have a resolution. Many thanks
Paul
Hi! Came across this myself and from memory this was down to the visible and enabled property on the field on the page. If you use one rather than the other you can still see the field. So set the visible to default rather than true and enabled to false. Still shows on page and you can see it.
Seem to remember this worked after a lot of trial and error.
Hope this helps.
Neil
Hi Neil, thanks for your reply. We got to the bottom of it, it was the bolt on Easy Security that was causing it. All sorted now. Cheers Paul
