I have created a report using the tables - Resource, Job, Job Planning Line and Job task.
In the report, the Department, Location and Job Title (from Resource data item) tagged to a particular resource (resource is present on Job Planning Line table) is not properly displayed.
For example, the Job Title for Resource A is getting displayed for all other resources which have other Job titles.
Could anyone please suggest me a solution.
I am attaching the source code for more reference.
Thanks !
Job Task Details Report :-
report 50201 "Job Task Details"
DefaultLayout = RDLC;
RDLCLayout = 'JobTaskDetails.rdl';
ApplicationArea = All;
Caption = 'Job Task Details';
UsageCategory = ReportsAndAnalysis;
dataset
dataitem(Resource; Resource)
RequestFilterFields = "Location", "Department", "Employee No.";
PrintOnlyIfDetail = true;
// DataItemLink = "No." = field("Employee No.");
// column(Location; Location) { }
// column(Department; Department) { }
// column(Job_Title; Job_Title) { } // Task owner designation
// trigger OnAfterGetRecord()
// var
// myInt: Integer;
// begin
// Employee1.SetFilter("AD user name", Job."Project Manager");
// Employee1.SetFilter("Job Title", Job."Project Manager");
// end;
// dataitem(Resource; Resource)
// //DataItemTableView = SORTING("Employee No.", "From Date");
// // DataItemLink = "No." = field("No.");
// RequestFilterFields = "Employee No.";
// PrintOnlyIfDetail = true;
dataitem(Job; Job)
//DataItemLinkReference = Employee;
//DataItemLink = "No." = FIELD("Employee No.");
DataItemLink = "Project Manager" = field("Time Sheet Owner User ID");
RequestFilterFields = "No.", Status, "Bill-to Customer No.";
column(FORMAT_TODAY_0_4_; Format(Today, 0, 4))
column(COMPANYNAME; COMPANYPROPERTY.DisplayName)
column(CurrReport_PAGENO; CurrReport.PageNo)
column(CurrReport_PAGENOCaption; CurrReport_PAGENOCaptionLbl)
column(Bill_to_Name; "Bill-to Name") { } //customer name
column(Bill_to_Contact_No_; "Bill-to Contact No.") { } //customer contact person
column(No_; "No.") { } //Job Code
column(Description; Description) { } //Job Description
column(Project_Manager; "Project Manager") { } //Job Owner // column(Job_Title; Employee."Job Title") { }
column(Job_Source; "Job Source") { } //Job Source
column(Projects_type; "Projects type") { } //Job type
column(Role__at_client_firm_; "Role (at client firm)") { }
column(Clientfilename; Clientfilename) { } //Clientfilename
column(Clientfilenumber; Clientfilenumber) { }
column(Clientmatternumber; Clientmatternumber) { }
column(ReceivedDateTime; ReceivedDateTime) { } //Date Time Job Received
column(DueDateTime; DueDateTime) { } //Due Date Time
column(Priority; Priority) { } //Job Priority
column(Starting_Date; format("Starting Date")) { } //Job Starting Date
column(Ending_Date; format("Ending Date")) { } //Job Ending Date
column(ReturnDateTime; ReturnDateTime) { } //Return Date Time
column(DeadlineRenegotiated; DeadlineRenegotiated) { }
column(OriginalDueDateTime; OriginalDueDateTime) { }
column(Status; Status) { } //Job Status
column(Feedbacktype; Feedbacktype) { }
column(Comments___from_the_client; "Comments - from the client") { }
column(ErrorRating; ErrorRating) { }
column(Comment_from_Exigent; "Comment from Exigent") { } //Internal Comments
dataitem("Job Planning Line"; "Job Planning Line")
//DataItemLink = "Job Task No." = field("Job No.");
DataItemLink = "Job No." = field("No.");
//column(Job_Task_No_; "Job Task No.") { }
//column(TaskDescription; "Task Description") { } //Task Description
//column(TaskDescription; Description) { }
//column(No; "No.") { }
column(No; Description) { } //Name of Employee working on task
//column(Task Owner Designation)
column(Quantity; Quantity) { }
column(Job_Task_No_; Job_Task_No_) { }
column(TaskDescription; TaskDescription) { } //Task Description
column(Job_Task_Type; Job_Task_Type) { }
column(Task_Classification; Task_Classification) { } //Task Category
column(Customer_Work_Type; Customer_Work_Type) { }
//Expected Hours To Complete Task
//Expected Starting DateTime
//Expected Ending DateTime
//Actual Starting DateTime
//Actual Ending DateTime
column(EmpLocation; EmpLocation) { }
column(EmpDepartment; EmpDepartment) { }
column(EmpJob_Title; EmpJob_Title) { }
var
myInt: Integer;
begin
Clear(Job_Task_No_);
Clear(TaskDescription);
Clear(Job_Task_Type);
Clear(Task_Classification);
Clear(Customer_Work_Type);
Rec_JobTask.Reset();
Rec_JobTask.SetRange("Job No.", "Job No.");
Rec_JobTask.SetRange("Job Task No.", "Job Task No.");
if Rec_JobTask.FindFirst then begin
Job_Task_No_ := Rec_JobTask."Job Task No.";
TaskDescription := Rec_JobTask.Description;
Job_Task_Type := format(Rec_JobTask."Job Task Type");
Task_Classification := format(Rec_JobTask."Task Classification");
Customer_Work_Type := format(Rec_JobTask."Customer Work Type");
end
end;
// trigger OnPreDataItem()
// var
// myInt: Integer;
// begin
// SetRange(ReturnDateTime, FromDate, ToDate);
// // //Job.SetFilter("Project Manager", UserId);
// // // Employee.SetFilter("AD user name", "Project Manager");
// // // Employee.SetFilter("Job Title", "Project Manager");
// end;
var
myInt: Integer;
//Rec_JobPlanningLine: Record "Job Planning Line";
//Rec_Resource: Record Resource;
begin
Clear(EmpLocation);
Clear(EmpDepartment);
Clear(EmpJob_Title);
// Rec_Resource.Reset();
// Rec_Resource.SetRange("No.", "No.");
// Rec_Resource.SetRange("No.", Rec_JobTask."Job No.");
// if Rec_Resource.FindFirst then begin
if Rec_Resource.get("Employee No.") then begin
EmpLocation := Rec_Resource.Location;
EmpDepartment := format(Rec_Resource.Department);
EmpJob_Title := Rec_Resource."Job Title";
end;
end;
requestpage
layout
area(content)
field(FromDate; FromDate)
Caption = 'From Date';
field(ToDate; ToDate)
Caption = 'To Date';
// trigger Onopenpage() //sets default value for the Status filter as 'Active'
// var
// myInt: Integer;
// begin
// Employee1.SetRange(Status, Employee1.Status::Active);
// end;
// actions
labels
// trigger OnPreReport()
// begin
// EmployeeFilter := Employee1.GetFilters;
// end;
var
FromDate: DateTime;
ToDate: DateTime;
Employee: Record Employee;
AbsenceFilter: Text;
EmployeeFilter: Text;
CurrReport_PAGENOCaptionLbl: Label 'Page';
Rec_JobTask: Record "Job Task";
Job_Task_No_: Code[25];
TaskDescription: Text;
Job_Task_Type: Text;
Task_Classification: Text;
Customer_Work_Type: Text;
EmpJob_Title: Text;
EmpLocation: Text;
EmpDepartment: Text;
