Most of the form and table browser is not displaying data in SQL i can see the record if i log in as some one else i can see those record but for me data is not visible.
I assume data has been imported as per MS guidelines. Also I assume that you have completed the checklists and compiled the system.
I don’t have AX in front. But run Periodic check under Basic > Periodic (if my memory serves me correct) with fix option. Before running this make sure database is backed up.
let me try this , but it happened to me some time back with other client and some one suggested that some patch needs to be reinstalled on the system .
But it was client location and very fast paced project they just created new id for me and that was working.
check data for consistency will take may be hour or so i will write back if that works
