Data is not displaying properly in the Role Centers.
These are setups followed during installation .
Installed Windows Server 2008 R2
Installed Sql Server 2008 standard Edition
Installed Sql Server 2008 SP1
Installed Analysis Services
Installed Reporting Services
Installed Ax 2009
Installed Ax 2009 Sp1
Installed AX 2009 GLS
Installed Ax 2009 Process Manufacturing
Installed EP
After installing Analysis Services. I processed the cubes. while processing the cubes I got the below error,
OLE DB error: OLE DB or ODBC error: Invalid column name ‘PAYMIDTYPE’.; 42S22; Invalid column name ‘SECONDTIN’.; 42S22; Invalid column name ‘TAX1099NAMECHOICE’.; 42S22; Invalid column name ‘DBA’.; 42S22; Invalid column name ‘TAXIDTYPE’.; 42S22; Invalid column name ‘FOREIGNENTITYINDICATOR’.; 42S22; Invalid column name ‘RESIDENCEFOREIGNCOUNTRYREGIO86’.; 42S22; Invalid column name ‘BIRTHPLACE’.; 42S22; Invalid column name ‘BIRTHDATE’.; 42S22; Invalid column name ‘FACTORINGACCOUNT’.; 42S22; Invalid column name ‘FISCALCODE’.; 42S22; Invalid column name ‘ORGANIZATIONNUMBER’.; 42S22; Invalid column name ‘TAX1099BOX’.; 42S22; Invalid column name ‘TAX1099REGNUM’.; 42S22; Invalid column name ‘TAX1099REPORTS’.; 42S22; Invalid column name ‘FEMALEOWNED’.; 42S22; Invalid column name ‘MINORITYOWNED’.; 42S22; Invalid column name ‘COMPANYIDSIRET’.; 42S22; Invalid column name ‘ENTERPRISENUMBER’.; 42S22; Invalid column name ‘COMPANYIDNAF’.; 42S22; Invalid column name ‘ORGID’.; 42S22; Invalid column name ‘W9’.; 42S22.
- I have just deleted those fields from cubes. And processed them again, the process has been completed successfully.
After that i got problems in Role Centers and I am unable to see the data on the Role Centers for different KPI’s
I just want to know the cause of the above error and why data is not displaying in the Role Centers. Any help would be greatly appreciated.
Thanks in Advance.
