Dear All
I tried to Bulk Uploading in Vouchers.
1st - i create a temp table & upload the relavent datas
2nd - i create the journal - and click the lines,
3nd - in the lines window - i created the Command button for inserting the data
Command Button - script (clicked event)
Public void clicked()
LedgerTable LedgerTable;
CustTable CustTable;
VendTable VendTable;
JournalId JournalNumLoc;
LedgerJournalTable LedgerJournalTableLoc;
VoucherUpload VoucherUploadLoc;
While Select VoucherUploadLoc
Where VoucherUploadLoc.JournalNum == LedgerJournalTable.JournalNum
ttsBegin;
LedgerJournalTrans.TransDate = VoucherUploadLoc.TransDate;
///////////// Ledger
Select LedgerTable
Where LedgerTable.AccountNum == VoucherUploadLoc.Accountnum;
if (LedgerTable.RecId)
LedgerJournalTrans.AccountType = LedgerJournalACType::Ledger;
Select LedgerTable
Where LedgerTable.AccountNum == VoucherUploadLoc.OffsetAccount;
LedgerJournalTrans.OffsetAccountType = LedgerJournalACType::Ledger;
///////////////Customer
Select CustTable
Where CustTable.AccountNum == VoucherUploadLoc.Accountnum;
if (CustTable.RecId)
LedgerJournalTrans.AccountType = LedgerJournalACType::Cust;
Select CustTable
Where CustTable.AccountNum == VoucherUploadLoc.OffsetAccount;
LedgerJournalTrans.OffsetAccountType = LedgerJournalACType::Cust;
////////////// Vendor
Select VendTable
Where VendTable.AccountNum == VoucherUploadLoc.Accountnum;
if (VendTable.RecId)
LedgerJournalTrans.AccountType = LedgerJournalACType::Vend;
Select VendTable
Where VendTable.AccountNum == VoucherUploadLoc.OffsetAccount;
LedgerJournalTrans.OffsetAccountType = LedgerJournalACType::Vend;
LedgerJournalTrans.AccountNum = VoucherUploadLoc.Accountnum;
LedgerJournalTrans.Txt = VoucherUploadLoc.Txt;
LedgerJournalTrans.AmountCurDebit = VoucherUploadLoc.AmountCurDebit;
LedgerJournalTrans.AmountCurCredit = VoucherUploadLoc.AmountCurCredit;
LedgerJournalTrans.OffsetAccount = VoucherUploadLoc.OffsetAccount;
LedgerJournalTrans.CurrencyCode = ‘INR’;
if (voucherUploadLoc.AmountCurDebit != 0 )
LedgerJournalTrans.AssessableValue_IN = voucherUploadLoc.AmountCurDebit;
if (voucherUploadLoc.AmountCurCredit != 0 )
LedgerJournalTrans.AssessableValue_IN = voucherUploadLoc.AmountCurCredit;
ttsCommit;
LedgerJournalTrans.insert();
LedgerJournalTrans_ds.create();
When i clicked the button, first record inserted - after that the below mentioned error shown.
Error : A new number cannot be assigned because CR-1112-001157 has not been saved or deleted.
Anyone help to resolve this issue.
Regards
Saravanan.R
