Data Import Export Framework Installation.
I have an issue regarding the installation of Data import export framework.
I have 2 instances of AOS (TEST and LIVE).
I have run the setup and selected all the 3 check boxes to install every thing on the server.
It goes fine without any error but the problem is when i run the script on the AXUTIL to import the axmodel it is running on the TEST instance where as i want to run it on the LIVE instance.
Where can i mention the instance name to import the model files into. By default it is importing on the test environment i want on live.
Please help.
Haiii friends,
I installed “data import export framework” in AX2012 TEST SERVER, it installed successfully,
but when i came to install in LIVE SERVER(AOS SERVER),in live server I dont have SQL MANAGEMENT STUDIO AND SQL COMPONENETS, in database server we have SQL management studio,in prerequisites it showing “microsoft sql server tools basic and complete”
waiting for solution
Thank u
Hai Mr.kami,
My issue also looking like same,
I installed data import export in TEST SERVER, it installed successfully,
waiting for solution,
Thank u.
