Data Import Export Framework for Project Journal Transactions (Hours) not calculating Sales Price
We found the sales price was NOT calculating on import of through the Data Import Export Framework (a.k.a. DIXF, DEIF, DIEF, DMF).
To fix this go to the DMFProjJournalTransEntityClass and replace the insertUpdate function with this (Directly after variable declaration but before any other code):
boolean priceFound;
_target.setCurrencyId();
priceFound = _target.setHourPrices();
_target.setTaxGroupId();
_target.setLineProperty();
ret = super(_target, _callInsertLogic, _callValidateLogic);
Note that the last line is the standard code, and that the remaining code (including priceFound variable) is from the standard fieldModifiedProjIdPostServer function of the ProjJournalFormTrans_Hour class, but that method is private. I could have also just called the Table ProjJournalTrans setHourPrices method “as is” - but if the hours aren’t calculating, the tax groups and currency might not be set either.
