Data Capturing
As a part of implementation, we are required to capture customer’s data. Do we have any pre defined formats which can be used for capturing master and setup information of the customer?
Are you asking the capturing of data from Navision, or from another program? Esat
No, there is no pre-defined method. What you probably want to do is create a Dataport with the required fields. Then export out the file with blank data from Navision using *.csv format. This will allow you to give Excel File to customers so that they can populate the data in Excel then import them back in Navision.
