Hi guys! How it it possible to: - Manage damage Stock in Navision4 - Make a damaged item not available for resale - Manage out of date item thanks
Create a location called RGA and receive all damaged stock into that. You can also create a loction for EXPIRED goods. I normally call those locations Z-RGA or Z-EXPIRED so that they are not mixed with true locations. BTW if you set SKUs at Expired to Standard cost, and set all costs to $0.00 then tey will bea automatically written off in accounting.
Thanks David! But is it still true even if the costing method is average?
