D365 F&O see the dual write outbound message
I am facing an issue in dual write when data is flowing from D365 F&O to CDS. Hence, I need to verify what exactly is the data that is flowing. Since I only have access to the F&O environment, I wanted to know is there any place from where I can see the exact Outbound message. Any help would be much appreciated. Thanks in advance!
DMF you can see the export and import of the Initial synch, if you mean the continual updates I believe the answer is no. If you have access to the maps in FO you have access to CE, the same user needs the rights for it to work.
