D365 access level for entry point in x++ comparison
how to use entryPoint.Grant.Create.ToString() for comparison, in if statement,
sometimes it returns right value, sometimes it returns integer value randomly, so it becomes garbage data ???
AxSecurityEntryPointReference entryPoint = enumeratorEntryPoints.Current;
if(entryPoint.Grant.Create.ToString() != ‘Unset’)
instead of Read sometimes it returns something like 52115489
all i need is to get:
  1. Direct access permissions of an specific privilege access levels
  2. entry points of a privilege access levels
both by code
What is the type of Create property?
it is
Microsoft.Dynamics.AX.Metadata.Core.MetaModel.AccessGrantPermission.Create
but i cannot declare such type variable too,
so i couldnt do a type comparison i tried
any of the below doesnt work
Microsoft.Dynamics.AX.Metadata.Core.MetaModel.AccessGrantPermission.Create create;
if(entryPoint.GetType().Equals(Microsoft.Dynamics.AX.Metadata.Core.MetaModel.AccessGrantPermission.Create) = true)
if(entryPoint.GetType().Equals(Microsoft.Dynamics.AX.Metadata.Core.MetaModel.AccessGrantPermission::Unset) == false)
this doesnt work too
if(entryPoint.GetType().Equals(Microsoft.Dynamics.AX.Metadata.Core.MetaModel.AccessGrantPermission::Allow) == true)
info(entryPoint.ToString());
the if statement doesnt go into if property is Allow
i tried with old TreeNode framework but it doesnt pick up a Security privilege entry points node
TreeNode treeNode = TreeNode::findNode(‘\Security\Security Privileges\’ + privilege.Name + ‘\Entry Points’);
