CustvendPaymProposal SSRS Report does not answer
AccountsPayable / Journals / Payments / Payment Ledger Form
Lines / Ledger voucher / action Panel => Print / Payment
(CustVendPaymProposal Output/CustVendPaymProposal - > Class/CustVendPaymProposalController
CustVendPaymProposal report does not give results.
  • CIL does not contain error.
  • Working with other reports.
  • Server Restart
  • Reporting Service Restart
  • http://REPORTSRV:80/Reports / report delete and AOT / CustVendPaymProposal / Deploy
I did them all but CustVendPaymProposal report are no results.
Dynamics AX 2012 R2 CU7
What can I do?
Thankyou
Can you please describe the observed behavior in better detail?
Hi Martin,
This screenshot in report. No error, no “Run Time Error”.
There are no results. I waited 5 hours.
Orjinal Report, no edit.
Thank You.
I suggest you use Trace Parser or debugger to see where all the time is spent.
Also look at this discussion thread: Payment proposal report “halts”.
Hi Martin,
I read the article, but the solution could not be found.
Then follow the advice I gave you.
The problem continues.
Check the temp Table “CustVendPaymProposalTmp” in SqlManagementStudio. There is records in Table.
I check the class wiht debug, I can view records too. (Class => CustVendPaymProposalController(method=>insertCustVendPaymProposalTmp))
Is (KB2885603) can affect my problem ? (Image1)
Hi tülay,
Where you able to find a solution for this problem ? I’m facing same issue.
Hi michal
I can not find solution. The problem continues.
Do you get an error?
Hi tulay,
In our case just simple restart of sql reporting services service helped.
I have done it after deleting all records from tmp table and checking locks on this table in sql server.
I sugest to try run this report in batch and you should get 503 error from reporting services immediately.
I think that general problem of this reprot is that they use sessionid as a key for tmp table.
So if sth goes wrong and user in one session will try to delete from this table locked rows - all will wait for database restart. key for this table should be made from session id + some execution id variable(or guid) - so you could get some uniqness. If all solutions fail I would suggest to correct the key to fix this for good.
Good luck!
thank you it worked like a charm
