Customizing report :
Hi All AXperts,
I am customizing Packing slip report. Purchase Order. Here , for the transaction lines, i have to show only 25 records per page and if it exceeds, it should move to next page…Also, for every 25 records, total Qty should be calculated for the Qty field…Plz help me how to do this?
Hi Enrique,
Declare a integer variable and create an counter for the same, and if the counter value is greater than 25 use the method element.newpage() so that the other records will be printed on the newpage.
Thanx Yeswanth :slight_smile:
