Dear Friends,
Good Day…
In Ax 2012 , I can able to debug all the development objects including Standard SSRS report but not Cutomized SSRS reports.Is there any other Procedure we need to do?. Actually i have given the user account to the microsoft Debugging Group in Active directory also. Even though i am not able to solve. Kindly Please help to get me out…
Thanks and regards,
Abbas.I
Have you unchecked the ‘Execute business operations in CIL’ checkbox in Tools>Options>Development?
Also you have to keep the debuger window open before the breakpoint hits the line.
Preeti
Hi Preeti,
Thanks for your reply.
I have tried but still am not able to debug the report.
Thanks And regards,
Abbas.I
Try this one:
http://technet.microsoft.com/en-us/library/gg724081.aspx
Have you tried debugging SSRS report earlier, I mean before the customization you made?
Hi Preeti,
I have filled all those settings which i have seen the above link but when i tried it is not triggering the debugger until unless should open the debugger window before going to run the report.
Thank you so much preeti…
Thanks and regards,
Abbas.I
Hi Abbas,
Glad to know that it helped you.
To stop at the breakpoint you set, AX Debugger must be running when you run the report.It is a must condition.
Preeti
