If there is some specific text for a customer each time their invoice is printed, how can this be done in report ?
The specific text will be at comment or user field at customer card.
Looking for pointer.
Lee
Lee
Hi ,
Didnt get you completely. are you looking for printing comments to a report?
follow www.archerpoint.com/…/how-use-extended-text-feature-microsoft-dynamics-nav
works in same way for customer’s extended texts.
Yes, it is to display/print standard billing instruction to one specific customer if their invoice is printed. Other customer invoices printing remain no change.
if it is specifically for one customer then as usual you can copy the text from record if it is common instructions then make Labels (as labels can directly used in RDLC)
Ok coming to part how you will find that customer
IF customer."No." = '10000' Then
IF NOT CurrReport.PREVIEW Then
Boolean := True;
in RDLC Layout insert text box and add labels to them and Set Visibility so that only for that customer it would print using above Boolean variable.
