Customize Ax 2012 Retail dlls
Haiii…
I have problem when try customize some of services library for AX retail, when i deploy dll into POS services folder and start the aplication it always showing error message “could not load all external service modules” and POS could not start.
Can anyone help me about this problem?
Thanks.
Whenever you make changes to the any of the services or Triggers and build the application . There is a possibility that others services or Triggers are dependent on the the service you modified. So to solve the problem you have to identity which other services and triggers are dependent on that service which you have modified. For example if you have modified Customer service, You are using customer DLL in Price Service then after building the Customer Service Project you have to add the new Customer DLL reference to the Price Project references. Hope this helps.
