Hi All ,
I am getting confuse about the vendor / customer master import in Axapta 2012 though Excel addin Vs DIE frame work .
if we want to the customer / vendor in AX 2012 , if it is through Excel Addin then you need to import atleast 3- 4 tables for customer or vendor as per the below link.
ax2012exceldataimport.blogspot.in/…/dynamics-ax-2012-customers-import-using.html
But if you try to import the customer / vendor through the Data Import/ Export framework 2012 , it is only one table is required , need not to import in different tables as per the below link.
axnmaia.wordpress.com/…/data-importexport-framework-walkthrough-importing-data
Could any one tell me which is correct way ?
I am really confuse about that how many tables we need to consider ?
