Hi, I’ve problem in standard “Customer Invoice Report” SSRS report where my temporary table getting populated but I’m not able to see that data on the print copy.
I’ve very tiny customization on the report. Still I’m facing this problem. Could any one please help me in this.
please make your table as regular and run the report when you see the values in table and not in VS then that’s means issue is in VS then you have to coentrate only one VS try to alter the design try using a auto design and please check whether the datasource is added correctly or not, deploy and build the project if the vaulues are coming in table and not VS issue lies in VS not in coding when you fix the issue you can change back the table as temptable
I’ve made My temporary table to Regular and I can see the table that has been populated by data.
Also I created a new Auto Design and used that DS and build, Deploy was successful Restarted Both servers . Unfortunately still report not showing the values…
I’m sorry that I do not think there’s a problem with the code actually because values are properly getting inserted into the table “SalesInvoiceTmp” but it’s not rendering to the report screen.
Hi Vinoth/All. Still you guys could able to get some ideas on solution for this issue you can share with me. I’m still facing the same issue(No data displaying on the report).
Hi , i am also facing same problem. Any one have solutions for the above problem. I have tried restarting both report sever and AOS. In addition i have different designs in report preview compare to AOT(one extra parameter is pop in report menu item (when running a report) but that is not in VS report preview.
Dear Sakthiananth,
I am facing the same issue, ssrs report not showing the data and data already inserted in to table. Kindly explain if you already resolved the issue.
