Can anyone suggest a solution steps on how to migrate customer and vendor open transactions from ax 2009 to ax 2012 using DIXF.
Thanks in advance,
Thanks in advance,
Can Anyone tell me the correct entity that can be used for customer or vendor transactions and basic setup required for the the same. Please suggest a solution.
Thanks in advance,
If you are looking for Opening Balances to be moved from 2009 to 2012, its Opening Balance Entity in DIXF that you had to use.
