Hi, starting with Win2000 (so it should work an XP too) you can design custom-sized forms globally for all printers and do not need a printer driver which supports this custom paper-sizes. If you open your printer window there is a menuitem called “Servereigenschaften” (or I guess “Server properties” in the english version) in the Datei/File menu. There you’ll find pre-defined paper-sizes. This is also the place where you create new forms. You’ll only have to create this form once and it can be used for all printers. So, define your custom form, add a new printer and set default paper-size to your custom-created form and use this printer for your report. Bye, Torsten
