I am designing a log form. Here I have a Enum field named Module which has 2 Elements AP,AR. Now i am creating a filter using Combo Box. My filter is working fine , i.e; when i select AP in Combo Box All AP records are shown and when i select AR all AR records are shown but the problem is how to display both at a time.
For this i Created one more Element in Enum as All and tried the following code but it is not working.
Example:
public void executeQuery()
if(Module.valueStr() == “Accounts Payable”)
qrModule.value(Module.valueStr());
else if(Module.valueStr() == “Accounts Receivable”)
else if(Module.valueStr() == “ALL”)
qrModule.value(enum2str(PEPSModule_RBT::AR));
qrrModule.value(enum2str(PEPSModule_RBT::AR));
What’s the point of your code for “ALL”? Assuming that qrrModule is a typo, it sets the same filter to the same range twice.
By the way, you have many weird things in your implementation, such as hard-code texts in one specific language. Let me show you nicer code:
switch (Module.selection())
case YourModuleFilter::SalesOrder:
qrModule.value(queryValue(ModuleAxapta::SalesOrder));
break;
case YourModuleFilter::PurchaseOrder:
qrModule.value(queryValue(ModuleAxapta::PurchaseOrder));
break;
default:
qrModule.value(SysQuery::valueUnlimited());
super();
Don’t forget that you told us little about your implementation (e.g. whether the field and the filter use the same enum), therefore I merely guessed some parts. You may need to modify the code to meet your specific needs.
(Question moved from the Technical forum.)
If it answered your question, please close the thread by marking the reply as the verified answer.
