Ho do i can make a textbox taken form toolbox and a global variable is assigned to its source expression.
HI Jatinder,
Open the Form in designer mode, GOTO–>View–>select Toolbox
Select the textbox and click on form then press Shift+F4(Goto–>View–>Properties) and assign the source exp.
For more help read C/SIDE solution development pdf.
Abhishek
