CurrForm.Update not working
I want the form to be updated after changing records in a table box, since the sorting order of records may change if you change key field values.
I put in the Form.OnModiyRecord trigger the CurrForm.Update; and as soon as it would run, the whole NAV simply shuts down. Is this my fault or system bug?
Gabor
Sounds like you have an infinite loop.
Try putting the update in the on after validate trigger.
Great, thanks for your help, now it works!
Gabor
You are welcome.
