Current System Time.....?
Hi Aall,
How to get current System Time in AX …?
Is ther any function…?
Thanks in Advance…[:)]
Hai Bobby,
use this systemDateGet Function
Three options -
  1. systemdateget()
  2. DateTimeUtil::getSystemDateTime() - this option as the name indicates will return the time part as well in UTC format
  3. DateTimeUtil::utcNow() - returns UTC time of the server
You may also want to read Vanya’s post on UTCDateTime in DAX 2009 (http://kashperuk.blogspot.com/2010/02/utcdatetime-in-dynamics-ax-2009.html)
You can use the following code-
static void getTime(Args _args)
int hour,minute;
hour=timeNow()/3600;
minute=((timeNow() mod 3600)/60);
print strfmt(“Time - %1:%2”,hour,minute);
pause;
Vinay
