Hello, how can i update a Date-Field automatically with the current Date? I want to use a Flow-Field, but it doesn#t work. thanx Axel a.schuhmacher@mps-solutions.de
The System function for getting the currrent date is TODAY. You cannot use a FlowField for doing this. What exactly are you trying to achieve?
Hi Schuhmacher, When you are talkinh about automatic filling the date, is that meaning filling the date when you open the form or running a process? If that’s the case then its easy. Tell us more about your problem? Naveen Jain
