In purchase Order invoice , while verified vouchers, if Execute business operations in CIL is checkedIn the currency conversions are not performed in some lines. Please suggestion a solution in ax 2012.
Thanks in advance,
Gopinath
Thanks in advance,
Gopinath
First of all, make sure that your CIL is up to date.
Then try to analyze when the problem occurs. Note that you can use the debugger to see what’s going on in code.
It is already been discussed here,
dynamicsuser.net/…/currency-conversion-is-not-working-for-vendor-invoice
