Currently i using AX 2012 R2 and the issue when i click at currency field purchLine form, it will change the value inside without selecting any other currency code. When unclick it will prompt original value.
Let say in purch Line i created is USD. when i click in currency field it will change to IND. when i click other field, will prompt USD back. anyone can help on this?
**Purch header set same as Line = USD.
**no purchase agreement set.
**vendor set as USD
