i have installed data base in one system and AOS on another system. When i try to update to CU7, database side update is successful but AOS Side it is giving error for DataImportExport feature update
Installer error at Specify SSIS location "Unable to connect to Microsoft Dynamics AX 2012 Data Import/Export Framework service running on SQL01. You must connect to a running instance of the service"
