CTRL + E From Customer Ledger Entries Generates Following Error Please Help
Microsoft Dynamics NAV excel add-in encountered an external error The type initializer for threw an exception
Hello Andrew,
I think you should try to reinstall the RTC Client. Had this problem too, I don’t know if exactly the same error but the reinstalling solved the problem!
Remove excel-addin with nav setup. Then try again.
