Using C/ODBC I have set up reports for my customers using Crystal Reports version 8. However, I have a problem when using the Crystal SQL designer. Whenever I get to the SQL tab I am unable to view SQL code and system gives an internal error and application aborts. I need to use the SQL designer to write SQL code direct without using the experts. I have been told that it could be that the Navision database is not 100% SQL compliant ? Can anybody give me some advise ?
We are looking for freelancers to help write some reports. Please contact me at 609.395.0550 Thanks
I am a freelancer but before I say yes or no it would be helpful if you would tell in which continent/country/area you are located and what kind of reporting skills are required. Marcus Marcus Fabian phone: +41 79 4397872 m.fabian@thenet.ch
