Crystal Reports and Navision Licences
If I use Crystal Reports to access the Navision SQL database does that use one of our Navision Client Access Licences? Thanks,
Yes it does. David
If you’re running the Navision Database and using Navision’s C/ODBC driver, then yes. But if you, as you state, are running Navision on Microsoft SQL Server, then you are connecting with the generic ODBC driver for SQL, then you’re not. But you are getting a not so user friendly implentation, as you’re seeing the SQL table and field names. And if you’re working with more than one company then it’s even worse… Instead when version 4.00 is release then you’re getting a “real” ODBC driver for Navision, with a real display of the Navision tables and fields.
